tachometer Does not work
Old Aug 30, 2011
subworm07's Avatar
subworm07 is an unknown quantity at this point
Hi Everyone I've had this problem for over a month now and cant figure it out my tach does not work.
I even trying connecting and after market one that I know works for a fact and it still does not work, I've checked all my fuse's both under the hood and under the dash and everything is fine. Any ideas what could be causing it not to work?
I've heard that if you could fry the vss in the Fuse box under the dash and that can cause it not to work is that true?
Thanks.
oh and I have and 02 civic ex
Old Aug 30, 2011
sl33pyriceboi's Avatar
Re: tachometer Does not work
search for multiplex and see if ur multiplex has taken a dump
Old Aug 30, 2011
subworm07's Avatar
Hi thanks for your reply.
I was looking into that, but it seems everyone that had a bad multiplex had tons off other problems. For me the only thing that's not working is the tachometer.
Old Aug 30, 2011
CraigW's Avatar
Have you done the cluster test to see if the tach works during testing ??
https://www.civicforums.com/forums/7...ster-test.html
Old Aug 30, 2011
subworm07's Avatar
I haven't done that yet I will try that today.
Old Sep 1, 2011
subworm07's Avatar
Just wanted to update this.
I found out that my tach wire got this disconnected while I was doing my conversion.
I removed the cluster yesterday and saw the wire just laying there reconnected it and everything is fine now. So thanks everyone for there help.
ORskier
May 3, 2015 12:54 PM
ashleymmackey
Apr 18, 2015 09:48 PM
McD
Apr 16, 2015 10:46 AM
htowncivicEX
Nov 13, 2001 04:30 PM
