2005 Civic overheating, no fan, no heat
Old Aug 9, 2011
dcwilkinson's Avatar
dcwilkinson is an unknown quantity at this point
My daughters car started overheating last night at midnight. When I drove the rest of the way home I noticed the fan was not kicking on and would over heat within just a few minutes. The first time I drove it about 2 miles and turned the heat on. It was very hot air. Then I pulled over to let the engine cool. Each segment there after the heat would not come through, just cold air. I check the fuses and coolant level and no issues. The coolant has not been messed with in the last year. Any ideas?
Old Aug 9, 2011
Re: 2005 Civic overheating, no fan, no heat
start with a new honda thermostat, then if the overheating stops but the fan still wont come on, try a new fan sensor. im pretty sure thermostat isnt opening enough and this is causing you not to get any coolant going to the radiator.
Old Aug 12, 2011
wetpinkpants's Avatar
wetpinkpants is on a distinguished road
I agree with him I would flush it and put a new thermostat in and make sure you bleed it when you are done. I would check your fans first unplug them and use jumper wires and connect to the battery. If they work then check the fan relays in the fuse box under the hood and then the fan switch
cooldan1
Apr 23, 2015 10:49 AM
jessicakaybby
Apr 20, 2015 12:11 PM
dano2005
Apr 14, 2015 01:58 AM
Pir8pete
165
Mar 6, 2009 05:16 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
