Dummy Lights & Signal indicators
Old Aug 4, 2011
Clunker's Avatar
Clunker is an unknown quantity at this point
I purchased a 99 Honda Civic DX Coupe this past weekend. I noticed something yesterday that kind of annoys me. It's strictly cosmetic, but irritating nonetheless. The color tint over the SRS, BRAKE, SEATBELT and turn signal lights are all cracked and faded. Can these be replaced? See pictures.
Old Aug 4, 2011
MindBomber's Avatar
Live for the Twisties
Re: Dummy Lights & Signal indicators
The simplest solution would be just getting a new cluster and swapping it in, I'm pretty sure those are actually painted onto the cluster.
Old Aug 4, 2011
CraigW's Avatar
I think they look cool, you would likely need a different cluster.
Old Aug 4, 2011
Clunker's Avatar
Swapping cluster is definitely not on the top of my list. They still work. Maybe I'll find an EX cluster.
Thanks.
Old Aug 4, 2011
CraigW's Avatar
Does your cluster sport an LCD odometer ?? The mileage may/may not be stored in the cluster ??
Is the EX cluster swap 100% plug and play ??
Old Aug 5, 2011
Clunker's Avatar
From what I've read, it's 100% plug and play on the 99. It is not an LCD odometer. I see that may pose a problem if the mileage isn't pretty close?
Old Aug 8, 2011
CraigW's Avatar
Keep your old cluster and write down the starting mileage for the new one.
Old Aug 8, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
That would really **** me off, too. Keep the original cluster around just in case. I would even go further and store the cluster information on a web document just in case you lose the paper or the cluster.
Old Aug 9, 2011
Stock 99's Avatar
I swapped a cluster out of my 99 civic a few months ago. It's easy.
...but a cheaper fix might be just to take it apart and use a sharpie or something to balance out the colour.
or maybe just find another platter (bottom left).
I dunno just some suggestions.
BTW - you can pop the speedo/odo out of the original cluster by undoing 4 screws on the back
Old Aug 9, 2011
Clunker's Avatar
or maybe just find another plater (bottom left).
This is the most interesting idea yet
Old Aug 9, 2011
lazlong's Avatar
Try the sharpie if you want. If it doesn't work PM me and I can get ya a used platter for super cheap at Pick-and-Pull. I saw a barely picked over '99 this weekend.
trellex
May 24, 2015 04:39 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
injencivic
Nov 9, 2007 02:31 PM
GhettoCivic
Nov 12, 2001 03:15 PM
sonsonzai
Nov 4, 2001 12:52 PM
