8th Gen 2006 - 2011.
Does an O6 have a timing belt or timing chain?
Old Jul 7, 2011
clayhill's Avatar
clayhill is an unknown quantity at this point
Arrow Does an O6 have a timing belt or timing chain?
I am reaching 100k on my 06 civic. On my previos civics I have changed the timing belt around 90k. What maintence should I do on my 06 at 100k and does it have a timing belt or timing chain?
Sorry for the loaded question. I appreciate the help.
-Clay
Old Jul 7, 2011
08EX's Avatar
08EX is an unknown quantity at this point
Re: Does an O6 have a timing belt or timing chain?
It has a timing chain. No maintentance interval mentioned in the shop manual other than if the tensioner pin exceeds a certain length, service is required. They don't even say when it should be inspected. I've heard the chain guides will wear out, but again no info on when to replace. I suspect as long as it is quiet and you don't get any cam timing error code, keep driving it.
Old Dec 5, 2013
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Yeah You have a chain on there. just remember to do Your oil changes on
a regular basis because the engine oil lubricates it. being your
"timing chain", should last the Life of the engine though with-out any
kind of inspection or maintenance required.
Old Apr 29, 2014
Zsoltster's Avatar
Zsoltster is an unknown quantity at this point
Not sure if this would be a hijack (if so, sorry) but is the "drive belt" the same as the "timing belt"?
Old Apr 29, 2014
CraigW's Avatar
No,
Drive belt, accessory belt.
Old Aug 9, 2015
ZoSoIV's Avatar
ZoSoIV is an unknown quantity at this point
2006 up all have a timing chain
Old Sep 26, 2015
06 EX Mild Mods's Avatar
06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about
Yes this was pleasant when I learned this, most cars have timing belts. Zsolster, the accessory belt is a serpentine belt that has a tensioner to keep it tight, it powers the AC compressor. power steering, alternator, water pump. The timing belt/chain controls the cam valve timing and is located typically on the passenger side of the engine under a cover.
mattdoc
Mar 14, 2017 12:10 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
