01 civic lx left turn signal not working?
Old May 13, 2011
Honda5224's Avatar
Honda5224 is an unknown quantity at this point
My right turn signal works perfectly fine. my emergency lights work fine also. bulbs are all fine. any ideas? by the way blinker is not blinking fast or sometimes. just not at all. doesn't light on the dash nor in the front or the back.
Changed the flasher and it did not work. i tried disconnecting the battery and connecting it again with the switch on. didn't work either. the light for the left turn signal on the cluster only lights up when i turn the emergency lights on, but not when i move the switch. Still have no idea what it is.
Old May 13, 2011
lowlife9's Avatar
Re: 01 civic lx left turn signal not working?
i would guess it has something to do with the switch itself.
Old May 13, 2011
make sure the bulb isnt shorting out in the socket. its a common problem if the bulb is sitting too far down at the bottom. first check the fuse, then if its blown replace it and reseat the bulbs but pull them slightly up so that they are not touching the bottom.
alexkharden
Apr 23, 2015 07:13 PM
Fastfebur
Apr 22, 2015 01:37 PM
GH04si
Apr 15, 2015 08:13 PM
eXNBP
Dec 9, 2001 12:32 AM
papi2001civic
Nov 3, 2001 12:09 PM
