01 civic lx left turn signal not working?
Rep Power: 0 01 civic lx left turn signal not working?
My right turn signal works perfectly fine. my emergency lights work fine also. bulbs are all fine. any ideas? by the way blinker is not blinking fast or sometimes. just not at all. doesn't light on the dash nor in the front or the back.
Changed the flasher and it did not work. i tried disconnecting the battery and connecting it again with the switch on. didn't work either. the light for the left turn signal on the cluster only lights up when i turn the emergency lights on, but not when i move the switch. Still have no idea what it is.
Rep Power: 789 Re: 01 civic lx left turn signal not working?
make sure the bulb isnt shorting out in the socket. its a common problem if the bulb is sitting too far down at the bottom. first check the fuse, then if its blown replace it and reseat the bulbs but pull them slightly up so that they are not touching the bottom.
alexkharden
04-23-2015 07:13 PM
GH04si
04-15-2015 08:13 PM
