Steering wheel column shaking more as 03 civic gets older. Why?
Old Apr 26, 2011
jgallag's Avatar
Livin' life
jgallag is an unknown quantity at this point
Hi all,
I had an eight hour drive yesterday in my 03 civic going up to 80 mph. The steering wheel and front dash was "shaking" as I got closer to 80. The faster I went, the more the shaking. It used to do that same thing at much higher speeds, though, when I bought it new (maybe 100 mph). This seems to be a common thing with cars (not just civics), in general. Why? Is there some way that I can tighten things up so that it won't shake when I get to higher speeds? Replace parts? I have good tires and they are balanced.
Also, how do you all clean your engine area? Some of you guys/gals have pics of really clean engines.
Thanks!
JEFF
Old Apr 26, 2011
MelJ's Avatar
Trance Addict
Re: Steering wheel column shaking more as 03 civic gets older. Why?
If you wanna go the extreme, you can pretty much follow these steps for bay cleaning:
http://www.honda-tech.com/showthread.php?t=2680235
Old Apr 26, 2011
RemyL31's Avatar
RemyL31 will become famous soon enough
Possible bent rim/rims
My old civic shook when going 70+
Found out it was a bad CV shaft...the boot wasn't ripped and it didn't feel loose, but after I changed it, the shakes went away..
Old Apr 26, 2011
MelJ's Avatar
Trance Addict
I saw wheel balance and typed it anyways. Force of habit I guess. Yeah. You could have bent rims. Often overlooked.
Old Apr 26, 2011
jgallag's Avatar
Livin' life
Thanks MelJ and RemyL31!! Other thoughts?
Old Apr 26, 2011
BlueEM2's Avatar
Whachya lookin at?
Do a front and rear suspension inspection and see if you come up with anything...
Old Apr 26, 2011
and don't go 100 MPH... especially in a car with dubious maintenance...
Old Apr 26, 2011
garden772's Avatar
2001 Civic LX
garden772 is an unknown quantity at this point
My Civic shook ALOT at low speed and at high speeds it would still rattle consistently I immediatly thought it was Motor Mounts but my Father insisted on the shocks/spring whole assembly but Of course i was right. Get the motor mounts inspected they do take a nice beating especially if you have upgraded your motor to higher performance levels.
Old Apr 26, 2011
higher performance level?!? civic Non-Si?!? bwaahahaha!
Old Apr 26, 2011
MindBomber's Avatar
Live for the Twisties
If the steering wheel is shaking then check your ball joints.
Old Apr 27, 2011
BlueEM2's Avatar
Whachya lookin at?
It could be anything on the front end, so get an inspection done. Everyone here can tell you its this part of the suspension or that part but in the end it could be anything.
Old Apr 27, 2011
jgallag's Avatar
Livin' life
Thanks everyone! Trying to troubleshoot without taking it to the shop.
Old Apr 27, 2011
MindBomber's Avatar
Well, ball joints generally cause the steering wheel to shake and isn't accompanied by other symptoms like bad tie rods.
moorebl
Aug 29, 2015 08:39 PM
bsmiley
Apr 27, 2015 01:27 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
colombianDXcivic
Nov 8, 2001 05:26 PM
