Heat shield falling off
This heat shield has rusted and broken around the bolts.
Would it be fine if I just cut it completely off?
Or, if I want to keep a heat shield, could I strap it on by, say, a big hose clamp?
Re: Heat shield falling off
normally i would say remove them all, i did, except for that cat shield. its important for the cat to stay hot and work properly. without that shield, it may not stay hot enough and the engine light can come on. You possibly may also fail a smog check. look into some metal zipties at the hardware store and use those to put it back together (may need to drill some holes in the shields to use the ties).
Munzy
21
Oct 7, 2015 07:48 AM
Elciteeve
Sep 28, 2015 12:40 PM
jsmithe2010
Sep 25, 2015 07:42 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
