Heat shield falling off
Old Apr 3, 2011
amodeoa8's Avatar
amodeoa8 is an unknown quantity at this point
This heat shield has rusted and broken around the bolts.
Would it be fine if I just cut it completely off?
Or, if I want to keep a heat shield, could I strap it on by, say, a big hose clamp?
Old Apr 3, 2011
MindBomber's Avatar
Live for the Twisties
Re: Heat shield falling off
You can remove it, it's pretty common for them to rust off like that.
Old Apr 3, 2011
normally i would say remove them all, i did, except for that cat shield. its important for the cat to stay hot and work properly. without that shield, it may not stay hot enough and the engine light can come on. You possibly may also fail a smog check. look into some metal zipties at the hardware store and use those to put it back together (may need to drill some holes in the shields to use the ties).
Old Apr 3, 2011
Ckutch02EX's Avatar
Ckutch02EX is an unknown quantity at this point
Mine fell off almost two years ago. You will be fine without it.
Old Apr 4, 2011
amodeoa8's Avatar
Thanks very much for the replies!
I have a coil of thin aluminum. Do you think that would make for a suitable strap?
Old Apr 4, 2011
RemyL31's Avatar
RemyL31 will become famous soon enough
I used radiator hose clamps on my old '98
Munzy
21
Oct 7, 2015 07:48 AM
Elciteeve
Sep 28, 2015 12:40 PM
jsmithe2010
Sep 25, 2015 07:42 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
fvckbg
Sep 8, 2015 09:55 PM
