1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1994 civic will not start usually after rainy days?
Old Mar 22, 2011
ebanuelos's Avatar
ebanuelos is an unknown quantity at this point
OK MY CIVIC WILL NOT START USUALLY AFTER RAINY DAYS. I HAVE NOTICED THAT MY FUEL PUMP DOES NOT PRIME WHEN THIS HAPPENS. I CHECKED FOR POWER AND HAD NONE, SO I WIRED IT DIRECTLY TO THE BATTERY AND THE FUEL PUMP RAN, BUT THE INJECTORS DIDNT OPEN. THEY OPENED ONCE THE CHECK ENGINE LIGHT TURNED OFF. I HAVE ALREADY REPLACED THE RELAY, AND THE WHOLE IGNITION SWITCH. WHAT CAN BE THE PROBLEM. ONCE I GET THE CAR TO START, IT WILL WORK THE WHOLE DAY WITH NO PROBLEMS????.. HEEEEEELLLPPPPPP
Old Mar 27, 2011
DRAM2500's Avatar
DRAM2500 is an unknown quantity at this point
Re: 1994 civic will not start usually after rainy days?
these cars are very bad for fried distributors, check your very carefully, mine had same problems.
Old Dec 24, 2011
mroutbd's Avatar
mroutbd is an unknown quantity at this point
My 89 Honda Crx HF won't start on rainy days-OK when it's not raining. I've changed the relay, still won't start. On dry days it starts fine. How do I go about checking the distributor for being "fried" as the other thread stated.
Old Dec 25, 2011
yeh found this thread, congrats. now look in this too.
https://www.civicforums.com/forums/2...its-humid.html
Old Dec 25, 2011
mroutbd's Avatar
Thanks for the direction to the thread. Real helpful. Should be able to figure out the problem now.
Old Dec 25, 2011
OMFG, did I do something useful in that thread?
Old Dec 25, 2011
Something as simple as a cracked distributor cap can kill the engine when it gets damp.
When it will run correctly on a dry day, try misting a little water from a spray bottle on the cap and plug wires. When it stumbles you know you hit a problem area. Replace parts as necessary.
If you change out a distributor cap, be sure to replace the rubber seal part #13 here:
Old Dec 26, 2011
a huge list of items that could be checked in this case (that's what, 4 cases since last week asking absolutely same thing?) so yes, very useful
Jonnie.
Jan 13, 2019 11:21 AM
usajags84
May 10, 2015 08:11 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
deus-ex
Apr 13, 2015 12:29 PM
