Replacement axle too short ?
Old Dec 15, 2010
wesintexas's Avatar
wesintexas is an unknown quantity at this point
I broke the Tripod Joint on the Inner CV joint on my drivers side axle shaft the other day and looked up some parts sites for a replacement.
I went to O'reilly auto parts with my broken axle, but when I laid the 2 axles next to each other the replacement was shorter by about 4 cm (+/- 1 cm).
It baffled me and the sales chick.
Why would they be different?
Here's a link to o'reillys site, part number 60-4190
http://www.oreillyauto.com/site/c/se...001&vi=1373251
Anyways, where can I get a proper driver's side axle for my 2k1 LX 4dr MT
Thanks
Old Dec 15, 2010
Re: Replacement axle too short ?
an axle slids on itself - they could be longer or not. compress both all the way and they should be same
Old Dec 15, 2010
wesintexas's Avatar
While at the store comparing the 2 axles I did try and extend the replacement one to try and make it the same length, but the difference was too significant.
If the exact length doesn't really matter than I guess this is a newbie thread.
Old Dec 15, 2010
a broken CV will extend more if the bearings came out. did you try to rotate the CV in the shafts to see if they compress more instead of trying to extend the new ones?
The suspension move and changes the distance to the transmission slightly, so to avoid the shaft popping out from the transmission casing, the axles are made to slide (at some extent, naturally).
I did not check if the part number is the right one, though. maybe someone else will butt in.
Old Jan 9, 2011
wesintexas's Avatar
Went to advanced auto parts today to pick up another CV shaft.
CV2134
http://shop.advanceautoparts.com/web..._1013295381___
It's also too short, the distance between the 2 boots is shorter than my old axle. So even if I compressed the old one it is longer.
Old Jan 9, 2011
MelJ's Avatar
Trance Addict
Have you tried Napa? That's where I got both my axles. Fit with no issues. I mean, like they said, it's gonna slide some, but if the difference is insane, then I'd try and check somewhere else.
Old Jan 9, 2011
wesintexas's Avatar
I would try Napa right now if the coding on their website wasn't all screwy right now.
check it out www.napaonline.com
Old Jan 9, 2011
MelJ's Avatar
Trance Addict
These are the online results I got:
http://www.napaonline.com/Search/Res...&NValue=12821+
I didn't pick a store, but you get the idea.
Old Jan 9, 2011
wesintexas's Avatar
Link isn't working for me.
Is the site displaying correctly for you?
EDIT: this is what the site looks like for me http://img143.imageshack.us/i/napa.jpg/
Old Jan 9, 2011
MelJ's Avatar
Trance Addict
Wow. That's weird. I opened it up in both Chrome and FF with no issues .
Old Jan 9, 2011
try again tomorrow - some hacker got in there
Old Jan 9, 2011
BlueEM2's Avatar
Whachya lookin at?
Though I have no personal experience. I have heard of awesome things about this place:
http://www.raxles.com/
Jigee
May 9, 2015 11:18 AM
green01civic
Apr 29, 2015 01:36 PM
dooner24
Apr 14, 2015 07:51 PM
thesushiboy
Apr 12, 2015 02:54 AM
Aznnp77
Dec 26, 2001 10:38 PM
