1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
head swap on a 93 civic
Old Nov 27, 2010
andersonj7927's Avatar
andersonj7927 is an unknown quantity at this point
i was wondering if a d16z6 vtec head will fit on a d15 block?
Old Nov 27, 2010
530matt's Avatar
530matt is an unknown quantity at this point
Re: head swap on a 93 civic
sure does, easily acomplished in a afternoon, make sure you get the z6 dist. as well.
Old Nov 28, 2010
thanks man
Old Nov 30, 2010
"goose"Jay's Avatar
"goose"Jay is an unknown quantity at this point
....and an adjustable cam gear, also i think you may need a z1 or y8 timing belt? not sure which one. make sure to remove the screw on the block for the oil to go through for vtec, and you will have to hotwire the plug in for vtec
Old Dec 1, 2010
my car is a civic Si hatch, the d16z6 lost oil pressure really bad so i yamked it out and put a d15 non vtec in it for now and if i can fix the d16 i wont put the head(d16) on the d15. ive plastigaged and found number 1 and 5 main journal to be outta spec by about .3 mm
Old Dec 3, 2010
"goose"Jay's Avatar
ive never seen someone use mm for spec measurements...its usually in inch format....strange but awesome. yea mini-mes arent hard to achieve, just hard to keep on the rd kinda like ls-vtec swaps. id say stick to your plan.
Old Dec 3, 2010
well its the inch measure ment is supposed to be .002 and the journals are closer to the mm gauge on the plastigage.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
May 10, 2015 08:11 AM
BREADFAN
Apr 15, 2015 08:58 AM
WhosYoDadday85
Nov 11, 2001 05:41 PM
sonsonzai
Nov 4, 2001 12:52 PM
