Serious question regarding suspension
ok so my stock struts blew. damn.
im leaning towards buying tokiko blue struts, but want to get another set of lowering springs also.
what lowering springs will give me the LOWEST possible drop.
i would resort to fully adjustable coilovers, but it's just a little (a lot actually) out of my budget.
so what do u guys think? WHAT LOWERING SPRINGS WILL GIVE ME THE LOWEST DROP? i pretty much want my em2 SLAMMED!
Live for the Twisties
Re: Serious question regarding suspension
I believe H&R makes 2.5 inch drop springs for EM2s, but pairing those up with a set of tokico blue struts would be a big mistake. Blues are meant for a 1.5-1.75 inch drop at the most, so if you want to drop more than 2 inches you'll need to either purchase Koni Yellows, or a higher end Tokico strut.
If you're looking for something similar to stock, get the KYB GR2. I just put them in my 02 ex. paid $110 per front at http://rockauto.com. They work great. Much better than stock, in my opinion.
Drop the cash for coilovers to get your car slammed. Like everyone mentioned above, max drop on blues is something like 1.5"-1.75"
Or find an airbag system for your car. That'll get your car slammed, too.
Since you seem to care about drop and not improving handling buy some raceland coilovers. They will set you back the same, if not less, as just the tokico shocks.
actually, it's a new find in the Miata world that the raceland works pretty well for performance (for the price - yes, that was a surprise, very hard to make kits that work well in miata's). Really not sure how the performance will be on the civic's, though, and an unknown factor is the longevity.
thanks.
I would think that the miata version have better shock valving. The more serious racers use them for the higher spring rates and the matched shock, but they don't slam the car, just a small (1"?) drop.
Prolly they did not do that good a job on the civic version of the ricelands.
So far some of the guys over there on ephatch have had racelands for like a year or 2 and no problems what so ever. There is another brand that basically is racelands with another brand name and they are even cheaper. They are called rokkor coilovers and they are like 10$ cheaper and you get a 3 year warranty. For real I would rather buy cheap coilovers and have to replace them every 3 years or so rather than replacing the expensive ones bout the same time as the cheap ones.
just stay away from chinese coilovers. and if you want lowered car for performance, 1.5 inch is about the limit and you can use the tokico hp with them. anything lower you will just hate driving and the handling will not be any better. not to mention all the suspension parts you will be replacing because they cannot handle the stress of a lowered suspension geometry.
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Touge
Ottawa
Jul 18, 2015 05:39 PM
Touge
Jul 18, 2015 05:35 PM
NoobyKid
Jul 13, 2015 07:53 AM
