Serious question regarding suspension
Old Oct 18, 2010
jaedubb's Avatar
jaedubb is an unknown quantity at this point
ok so my stock struts blew. damn.
im leaning towards buying tokiko blue struts, but want to get another set of lowering springs also.
what lowering springs will give me the LOWEST possible drop.
i would resort to fully adjustable coilovers, but it's just a little (a lot actually) out of my budget.
so what do u guys think? WHAT LOWERING SPRINGS WILL GIVE ME THE LOWEST DROP? i pretty much want my em2 SLAMMED!
Old Oct 18, 2010
02civicsi02's Avatar
Low and slow!
Re: Serious question regarding suspension
Skunk2 springs will probably get you the lowest but you are not going to be slammed. If you want to be slammed then get some coilovers.
Old Oct 18, 2010
Mad Dog Tannen's Avatar
The manufacturer should give specs on how much lower you will go.
Old Oct 18, 2010
sam68's Avatar
sam68 is an unknown quantity at this point
You cant be "SLAMMED" on blues 1.5" at most.
Old Oct 18, 2010
another guy rolling the fenders out...
Old Oct 19, 2010
sl33pyriceboi's Avatar
sell me ur stock shocks. i jsut need the front right.
Old Oct 19, 2010
MindBomber's Avatar
Live for the Twisties
I believe H&R makes 2.5 inch drop springs for EM2s, but pairing those up with a set of tokico blue struts would be a big mistake. Blues are meant for a 1.5-1.75 inch drop at the most, so if you want to drop more than 2 inches you'll need to either purchase Koni Yellows, or a higher end Tokico strut.
Old Oct 20, 2010
MoreRicePlease's Avatar
MoreRicePlease has a spectacular aura aboutMoreRicePlease has a spectacular aura aboutMoreRicePlease has a spectacular aura about
If you're looking for something similar to stock, get the KYB GR2. I just put them in my 02 ex. paid $110 per front at http://rockauto.com. They work great. Much better than stock, in my opinion.
Old Oct 20, 2010
Drop the cash for coilovers to get your car slammed. Like everyone mentioned above, max drop on blues is something like 1.5"-1.75"
Or find an airbag system for your car. That'll get your car slammed, too.
Old Oct 21, 2010
lordhelmet's Avatar
Since you seem to care about drop and not improving handling buy some raceland coilovers. They will set you back the same, if not less, as just the tokico shocks.
Old Oct 21, 2010
actually, it's a new find in the Miata world that the raceland works pretty well for performance (for the price - yes, that was a surprise, very hard to make kits that work well in miata's). Really not sure how the performance will be on the civic's, though, and an unknown factor is the longevity.
Old Oct 21, 2010
lordhelmet's Avatar
People on ephatch have been running them for many thousands of miles. Any of them that have had problems have gotten new coilovers from the company. The consensus is that the em2/es1 racelands are to soft for serious performance but they go incredibly low for a very low price. Since OP stated he wanted to go as low as possible this system seems to suit his needs. As you know, as low as possible does not result in the best handling possible.
Old Oct 21, 2010
thanks.
I would think that the miata version have better shock valving. The more serious racers use them for the higher spring rates and the matched shock, but they don't slam the car, just a small (1"?) drop.
Prolly they did not do that good a job on the civic version of the ricelands.
Old Oct 21, 2010
Low and slow!
Lordhelmet is right actually. There is alot of people on ephatch running the racelands and have held up for a good while.
Old Oct 21, 2010
they're for my koni yellows. i want a new shell for them.
Old Oct 21, 2010
lowlife9's Avatar
racelands are dangerously cheap coilovers i would never consider that brand i would rather drive stock.
Old Oct 22, 2010
lordhelmet's Avatar
I've seen catastrophic failures on coilovers 3-4 times the price of racelands. At least with racelands the will give you a new coilover under warranty.
Old Oct 22, 2010
Low and slow!
So far some of the guys over there on ephatch have had racelands for like a year or 2 and no problems what so ever. There is another brand that basically is racelands with another brand name and they are even cheaper. They are called rokkor coilovers and they are like 10$ cheaper and you get a 3 year warranty. For real I would rather buy cheap coilovers and have to replace them every 3 years or so rather than replacing the expensive ones bout the same time as the cheap ones.
Old Oct 22, 2010
just stay away from chinese coilovers. and if you want lowered car for performance, 1.5 inch is about the limit and you can use the tokico hp with them. anything lower you will just hate driving and the handling will not be any better. not to mention all the suspension parts you will be replacing because they cannot handle the stress of a lowered suspension geometry.
Old Oct 22, 2010
lordhelmet's Avatar
All he said was he wanted to go low for cheap with no regards to improved handling.
Old Oct 22, 2010
jaedubb's Avatar
thank you guys for all your feedback. will follow up when mod's are made. thanks again you guys are great
Strycker
Aug 2, 2015 08:40 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
NoobyKid
Jul 13, 2015 07:53 AM
