Ok to use eBay tie bar with rear sway from RSX?
Old Oct 24, 2010
2k2civic's Avatar
So I'm buying a RSX type s sway (19mm) and I'm wondering if one of those cheapie eBay rear lower tie bars would be enough to reinforce the lca mounts. If not, can you recommend an inexpensive product that would work as a reinforcement?
Old Oct 24, 2010
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
Re: Ok to use eBay tie bar with rear sway from RSX?
i have a rsx beaks lower tie bar... also a subframe brace would help to reinforce it
Old Oct 24, 2010
lordhelmet's Avatar
No need to reinforce on 7th gens. I'm running a 21 mm bar without a tie bar. Works just fine.
Old Oct 24, 2010
Muirsy's Avatar
there mostly their for the bling factor
Old Oct 24, 2010
2k2civic's Avatar
That's the same thing I read about getting upgraded endlinks too - everyone said the stock endlinks are fine but I snapped my stickers with the stock sway bar do I'm a little afraid of breaking something.
Old Oct 24, 2010
lordhelmet's Avatar
The only reason they are there is bling factor. I've yet to break an endlink or rip the control arms out of the sub frame. Spend your monies on a better set of tires or n2o or something.
JohnnyBxo
Nov 12, 2015 03:04 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Causemo
Jul 4, 2015 07:11 AM
Makeice3498
Jul 2, 2015 11:13 AM
