my custom endlinks
my custom endlinks
after a week or so of studying pics of grey's and hotchkis endlinks, i decided that i'm gonna make my own and i did just that and here's the catch my endlinks only cost me around 35 bucks for all the parts. and finally here are the pics i've been promising
here's all that i needed to build my endlinks
you need 2 male ball joint ends and 2 female ball joint ends those are the middle sections screwed together, their mostly used on go-karts so if you have a local go-cart store around they should have something like them but i had to order mine off a site
link for the male sections http://www.mcmaster.com/asp/enter.asp?partnum=2458K141+
link for the female sections http://www.mcmaster.com/asp/enter.asp?partnum=2458K341+
the rest is basic stuff you can find at any hardware store
4 3/8 bolts grade 8
8 3/8 washers
4 3/8 lock washers
6 3/8 nuts
and some bushings, you can use the energy suspension sway bar link bushings they come in 3/8 i just had some laying around my work.
4 3/8 bolts grade 8
8 3/8 washers
4 3/8 lock washers
6 3/8 nuts
yea true good point on that but its a simple thing that anybody can build so thats exactly what i did. i'm upgrading both sway bars on my car and i wasn't gonna pay close to 100 bucks for them. so i built my own for half that price
well thats the thing alot of us don't know how like me so thats how you make money. come up with a good idea that everybody wants and doesn't know how to make. you'll be rich someday lol
great diy, man.
I installed the progressive front & rear sway bars on my car, but used the stock endlinks. bad idea. the endlink allen wrench socket was so rusted, it stripped while I was taking it off.
when it gets warmer out, I'm definately making these and swapping the stock ones out.
Good idea man!
I got Grey's endlinks and they've been great<--lol..
Anyways..I give you props for making these yourself..$50 you save is $50. The two o-rings on each are a great idea; they'd probably reduce noise and act as a damper no? Is that why you put them, cause mine make a lot of noise when going over bumps or bad roads..
exactly what /\ said if you have time to post on here you have the time to order those 4 ball joint ends and go to a hardware store and get some basic parts
Originally Posted by mrDFWmechanic
whats your setup ?
I saw some before I think are manufactured by hotchicks..they have like a special teflon or some **** inside the rod end's bushing.. I'll see if I can get a pic..
