Dropping is a Pain!
Alright so I've compiled a list after hearing from many of you. I thought I could just drop my car lol, but it seems a lot needs to be replaced when doing so. Please check out the list that follows and let me know if anything I list is not needed or add anything that you think I may need. Thanks for everything guys.
Tokico Blues
Eibach SportKit
New Mounts*
New Bearings*
New bushings*
Camber Kit
Lower Control Arm Bushings*
Swaybar Endlinks*
Parts with stars- Can you suggest a brand or where to get them for a relative low cost?
Tokico Blues
Eibach SportKit
New Mounts*
New Bearings*
New bushings*
Camber Kit
Swaybar Endlinks*
Re: Dropping is a Pain!
u dont really need half of that for a proper drop.
blues, sportkits and a camberkit is enough. then get it aligned...
the bushings, bearings, control arms are just more for if u want that every last bit of performance handling
....but if u really wanted handling blues/sportkits are not the way to go. they suck compared to yellows/GC or some tein flex or SS.
overkill indeed on the unnecessary parts...but depending on the climate you live in, your mileage, wear and tear and if your existing suspension has seen better days or your experiencing knocks, rattles and bangs you must have over studied for this test my friend...you have a good parts list though!!!
you can either change it out all together, or just do the springs/shocks/camber and then wait as parts start to break one by one. none of those stock components were made to handle a lowered ride height and will not last very long. if you dont do the strut mounts which are cheap and easy while replacing the shocks, then you will have to redo the entire install when you start hearing clunking sounds later. the lca bushings are prolly already broken anyway, or they will be soon. you could keep the stock endlinks i guess til they snap if you want to save some $$>
and after all this, you wont have to worry about anything for at least 5yrs, when you might need new shocks (and possibly alignment check every year just to be safe).
Tokico Blues
Eibach SportKit
New Mounts*
New Bearings*
New bushings*
Camber Kit
Swaybar Endlinks*
Tokico Blues
Eibach SportKit
New Mounts*
New Bearings*
New bushings*
Camber Kit
Swaybar Endlinks*
Can I not just go to NOPI.com and get an Eibach Anti-Roll Kit and/or a full LCA or Sway Bar instead of just buying these new boots and mount pieces to fit onto my stock stuff?
http://www.nopi.com/dsp_parts.php?vsubpcdesc=Suspension | Sway Bar
The LCA bushings could pass for a quick visual check, but have compliance bushings in hand already.
If whole arm is cheapaer than the work of swapping bushings, you could do them and have spares to install poly bushings later.
got mine for 100 something, not sure where but was internet site.
TheRiddicles
Sep 21, 2015 03:34 PM
TheRiddicles
Sep 21, 2015 01:28 AM
powman02
Sep 15, 2015 07:38 PM
