Normal Spark Plug?
Old Jul 20, 2010
97 Civic coupe's Avatar
97 Civic coupe is an unknown quantity at this point
Normal Spark Plug?
I was just wondering if this is what spark plugs should look like. The electrode is fine but does all of the black soot on the threads mean anything?
ID:	78748   Click image for larger version
Old Jul 21, 2010
cueist63's Avatar
cueist63 is an unknown quantity at this point
Re: Normal Spark Plug?
too rich a fuel mixture.
Old Jul 21, 2010
FGsmasher's Avatar
FGsmasher has a spectacular aura aboutFGsmasher has a spectacular aura aboutFGsmasher has a spectacular aura about
^^That.
Old Jul 21, 2010
Thanks! I've suspected a bad oxygen sensor for awhile now so I just ordered one. Hopefully that will fix it.
Old Jul 22, 2010
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
Is that all that it takes to cure the problem? Replacement of the O2 sensors?
Old Jul 22, 2010
It can be. If the oxygen sensors are giving the wrong fuel to air ratio you can burn too rich or lean. They typically only last 100,000 miles. My fuel economy has suffered lately which is also a sign that the O2 sensor should be replaced.
Old Jul 22, 2010
Nosepicker's Avatar
Good to know. Thx.
Do you know how much they cost? Or rather know where I can get them for cheap?
Old Jul 22, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Originally Posted by Nosepicker
Good to know. Thx.
They are not that cheap, if you go aftermarket make sure you get one that has the harness plug, not a universal model.
Old Jul 22, 2010
i ordered mine brand new from amazon for $50. Same exact one at autozone is over $100. Through Honda it'll be a ton. But yeah make sure it has the harness.
Old Jul 23, 2010
Nosepicker's Avatar
Thanks.
Anyone know the part/model #?
Old Jul 25, 2010
Thanks.
I ordered the Bosch 13249. It's a pretty good one. There are cheaper ones available though. With Amazon you can type in your specific car and it'll tell you which ones will fit.
Old Jul 28, 2010
Just installed the new o2 sensor today. Car is running better so hopefully that'll fix the rich mixture
danace99
23
Jun 28, 2015 08:49 AM
Kaelin
Jun 19, 2015 04:19 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
MikeyBoy
Jan 26, 2002 06:45 AM
Micks2K1
Dec 10, 2001 07:11 PM
