Door lock problem
Old Jul 11, 2010
SD.Norm's Avatar
SD.Norm is an unknown quantity at this point
Door lock problem
Hello, my girlfriend has a 2003 Civic EX Coupe recently the driver door will not unlock or lock with the remote or the switch in the car. You can unlock it with the key and by pulling the plunger up. Also when locking it you have to pull up slightly on the door handle. Any information would be very helpful. Thank you
Old Jul 13, 2010
civicbyrc's Avatar
civicbyrc is an unknown quantity at this point
Re: Door lock problem
You door lock actuator has gone bad. It is attached to the lock and is what lock and unlocks your car. It's not that expensive of a part ,but its kind of difficult to do. You have to take the door panel of and the the whole lock assembly has to come out ( the part the the rod on the body latches onto) and then you have to take it apart to change the actuator. Were are you at I can do it for you for a price? I'm in Washington state.
Old Jul 15, 2010
SD.Norm's Avatar
Thank you, I think I should manage to get it I am a metal fabricator so I am not to bad at working on things. I also live in Pennsylvania which is a little bit of a drive for you.
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
MamaBear2015
May 18, 2015 07:37 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
