1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
94dx idies then drops and gos back up
Old May 25, 2010
94cdx's Avatar
94cdx is an unknown quantity at this point
my 5 speed 1.5 has bin blowing a little black smoke then cel came on, taking longer to start then started bucking bad around 2500 rpm under load. it has a new fule filter seems to be elec. issue Im new to civics can anyone give me a good place to start.
Old May 25, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: 94dx idies then drops and gos back up
Have you cleaned your injectors?
Old May 25, 2010
94cdx's Avatar
no you think that would stop the idie issue the bucking just started with no warning
Old May 25, 2010
BlueEM2's Avatar
Whachya lookin at?
It might help the bucking issue. Is the idle going up and down smoothly or is the car bogging up and down?
Old May 25, 2010
RonJ's Avatar
RonJ will become famous soon enough
Pull the CEL code.
Old May 25, 2010
94cdx's Avatar
when i start the car cold it idles at like 1500rmp then will just drop to 600 then back to 1500 something like this then cel comes on
Old May 25, 2010
94cdx's Avatar
dont have a scaner so im troubleshooting before i go to bed
Old May 25, 2010
BlueEM2's Avatar
Whachya lookin at?
Check the code. I bet you that your throwing a TPS sensor code. A good shop will pull the code for you for free.
Old May 25, 2010
slty_wtrs's Avatar
slty_wtrs is an unknown quantity at this point
check your coolant. if the coolant is full maybe its the sensor that reads the temp to warm up a cold engine. (sorry cant think of the name right now) (((thats just for the idle up and down)))
Old May 25, 2010
RonJ's Avatar
You only need a paperclip or short piece of wire:
http://www.honda-tech.com/showthread.php?t=1901557
Old May 26, 2010
94cdx's Avatar
cool when i get a chance i'll try that thanks
Old Jun 23, 2010
voxleo's Avatar
voxleo is an unknown quantity at this point
I have a 95 ex coupe that had a high idle at startup that would drop about half the rpms when it ran a little but I was always low on gas; Now that I have filled the tank again it seems to have stopped but my CEL came on also. This was a little different from a previous problem I had with the Idle surging and dropping repeatedly as well as running hot which was due to an air bubble in the coolant system. Did you recently have any work done on the car? I got the bubble at the same time I had the clutch replaced (and possibly the water pump, but I don't recall exactly). Properly bleeding the coolant system solved the issue immediately with the surging and the temp issues.
I just did this myself today (easy and it works but I have no idea what to do now that I have the code =D). I had a little trouble finding the right place to look on mine but a compilation of several threads helped me find it under the rt side of the glove box about an inch from the kick panel. Mine had a 3 pin and a two pin plug (both blue) no rubber housing, just kinda tucked up next to each other in a groove- the two pin was the one I was looking for. If you don't catch the code the first time it will repeat so keep watching for confirmation.
Poopies
Apr 20, 2017 11:36 PM
crowtoo
May 11, 2015 06:50 PM
redej2
Apr 29, 2015 01:47 PM
colombianDXcivic
Nov 12, 2001 11:40 AM
blueracer
Nov 11, 2001 09:54 PM
