need help on valve adjustment b18c turbo
i have a b18c turbo starting to hear valve tick ,what is a good setting to set the exhaust valves.stock is 0.007 to 0.008. is 0.008 ok or should i go higher
remember tdc and cold engine is when you start valve adjustments
remember tdc and cold engine is when you start valve adjustments Re: need help on valve adjustment b18c turbo
i would set the valves to their stock lash settings unless you have in aftermarket camshafts, which would then lead you to set them to their preferred specifications.
fred57
Aug 1, 2015 08:45 AM
NROD315
Jul 21, 2015 07:46 PM
Jul 12, 2015 11:54 AM
