need help on valve adjustment b18c turbo
Old Apr 17, 2010
sureshot1979's Avatar
sureshot1979 is an unknown quantity at this point
i have a b18c turbo starting to hear valve tick ,what is a good setting to set the exhaust valves.stock is 0.007 to 0.008. is 0.008 ok or should i go higher remember tdc and cold engine is when you start valve adjustments
Old Apr 18, 2010
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
Re: need help on valve adjustment b18c turbo
i would set the valves to their stock lash settings unless you have in aftermarket camshafts, which would then lead you to set them to their preferred specifications.
Old Apr 18, 2010
02civicsi02's Avatar
Low and slow!
Adjust them to where they are suppose to be.
EdGasket
40
Nov 27, 2015 11:11 AM
fred57
Aug 1, 2015 08:45 AM
NROD315
Jul 21, 2015 07:46 PM
Jul 12, 2015 11:54 AM
General 7th Gen
Jul 9, 2015 10:17 PM
