1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
89 civic lx wont start
Old Jan 25, 2010
dedlyvirus's Avatar
dedlyvirus is an unknown quantity at this point
recently my car stopped starting. it was cranking, but would never actually start. first i thought it was the battery, jumped it, still nothing. so then i pulled the spark plugs and am getting spark at all the plugs. so then i thought maybe it wasn't getting gas. so i tried to listen for the fuel pump, and didn't hear anything. so i tested the fuel pump relay according to the haynes manual, and it seemed to work fine. so i replaced the fuel pump in the tank. i replaced the fuel filter in the engine bay. so i went to go start it, and it is doing the same thing. i pulled the supply hose off the fuel filter to see if gas was getting there, but when i tried it, nothing was coming out. so im thinking its not getting any gas, and i know there is gas in the tank because i put about 5 gallons in after i put the tank back in. so now im lost, i dont know what it is. when i turn the key i can hear the fuel pump kick on, but its not a whirring sound, its like a low hum almost. i dont know now. any help will be greatly appreciated.
Old Jan 25, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: 89 civic lx wont start
Check for a clogged or pinched fuel line between the gas tank and filter.
Old Jan 26, 2010
dedlyvirus's Avatar
well i went back and double checked my work. i was pinching the supply line at the gas tank. so i fixed that. i am now getting fuel to the fuel filter. The car is still doing the same thing, cranking but not starting. But not, the oil pressure warning light and the battery warning light stays on. Anyone know what that means? the battery is probably close to being completey dead, but everytime i try to start it i jump it from another car. thanks again.
Old Jan 26, 2010
RonJ's Avatar
Charge the battery, measure the fuel pressure, and check for spark at the plugs.
Jonnie.
Jan 13, 2019 11:21 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
