1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
91 hatch PLEAASSSE HELP
Old Jan 19, 2010
Travispatoka's Avatar
Travispatoka is an unknown quantity at this point
Exclamation 91 hatch PLEAASSSE HELP
hey everyone i have a 91 hatch with a b18a1 swap done to it, now i didnt do the swap i got it like that (yeah i know stupid idea) but it ran and drove great for about 2 months. then it started acting really weird with the electonics and stuff. the last time the car ran all it would do was idle and as soon as i put it into reverse and the lights would come on the car just shut off. i can take the key out of the car and set it on the roof and step on the brake pedal and all the dash lights will turn on seat belt check engine brake light all those nice lights, with out the key even being in the car. i can also turn on the headlights and then turn the turn signal on and it makes this really loud buzzing noise......the car hasnt ran in over 2 months now due to it getting cold out and after working on it hard core for a week and getting frustarated i gave up but i need to get it running again so i can either sell it or drive it the battery and the alt in the car are good i had a mechanic buddy check them for me, be he is also stumped on the reason the car dosnt run. does anyone have any ideas i would really apprecate them thanks for looking guys
Travis
Old Jan 19, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: 91 hatch PLEAASSSE HELP
For the problem with the brake lights turning on the dash lights, you either have the wrong brake bulb type installed (should be double rather than single filament buld) or the ground wire for the lights in the rear is disconnected or broken. Start with the former.
For the won't run problem, do you have any CEL codes? Have you checked the mechanical timing?
Old Jan 20, 2010
well i havent changed the bulbs in the back at all, and the car did run fine.
and its not throwing any codes at all ive checked a few times now
Old Jan 20, 2010
JDM_Ricer's Avatar
JDM_Ricer is an unknown quantity at this point
I would replace all the wire harnesses just to be on the safe side. Who knows the retard befor might have hacked the hell out the harnesses.. YOU really never know until you get in there and check em out..
Old Jan 21, 2010
yeah the harness in the car is all kinds of hacked up. the car had nos in it when it still had the stock motor in it the car was a hack job for sure but i picked it up for like 200 dollers i figured the b18 and the type r tranny were worth that atleast haha do you know what harnesses i should replace the one on the motor seems to be fine its the one in the car like under the dash and **** that i need? their is a hack job going on around the ecu two
thanks for helping me out
Old Jan 22, 2010
JDM_Ricer's Avatar
yeah find the dash harness and engine wire harness.. two main ones i would replace..
Old Jan 22, 2010
TRIZ's Avatar
If he has a swap, the engine harness isnt going to just plug right in...
Man, get a hold of the guy that sold it to you and tell him its all types of ****ed up and that you'd like his help fixing it since he did the work.
Old Jan 22, 2010
thats just the thing when i bought it from the kid he wasnt the one that did the swap, he bought it from another guy that did the swap. i just dont understand why the car would run great for him and never give him a prob and run good for me and then all of a sudden just start acting up, i didnt change anything in the car since i have had it except rims and exhaust i deff learned my lesson about buying other ppls swaps. ill just stick to doing my own again from now on
do you happen to know what plugs and **** wouldnt mount right back up if i got a new harness? the car is obd 0 clearly and the motor is obd1 i know i need a jumper harness for the ecu but if i get a harness for the obd1 motor wont it match up
Old Jan 22, 2010
TRIZ's Avatar
I would check over on honda-tech, they are all about the older civics there.
Old Jan 22, 2010
RonJ's Avatar
Have you checked the rear ground wire and the mechanical timing?
Old Jan 22, 2010
Rear ground wire?. The car is timed we have checked it a few times but i could still be wrong, where is the rear ground wire at?
Old Jan 22, 2010
RonJ's Avatar
Check G511 and make sure that the cam and crank are synched at TDC1:
Old Jan 24, 2010
i checked the ground wire and it is connected well, i took it off and rubbed it on some sand paper and put it back on, car still does it. i checked the timing and its set dead on, tcd1 Im just confused at this point
Hatchness
Sep 14, 2015 09:02 AM
yyyktk1
Sep 12, 2015 04:02 PM
Monty022581
Aug 31, 2015 08:32 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
