1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
90 civic- sputters and stalls at low rpm
Old Jan 15, 2010
bella_bean's Avatar
bella_bean is an unknown quantity at this point
I am hoping someone can help me!!!
so i have a 1990 honda civic 1.5, hatchback
it starts fine, yet a soon as at warms up it begins to sputter then stall, if you keep it in the high rpms you can keep it going for a little bit longer ( but it screams!) and then it wont start when you go to start it again. and the engine light is NOT on.... we have already changed, the thermostat, fuel filter, fuel pump and main relay and we are out of ideas.....
can anyone please help, it would be greatly appreciated!!
Old Jan 15, 2010
Re: 90 civic- sputters and stalls at low rpm
did you try taking apart intake system parts and cleaning with carb spray? also check the cap and rotor, plugs, wires, etc.
Old Jan 15, 2010
RonJ's Avatar
RonJ will become famous soon enough
If the problem only occurs after the engine is fully warmed up, then try unplugging the O2 sensor. If this makes the probelm go away, replace the sensor.
mrohitredd
May 30, 2015 06:51 PM
mrohitredd
18
May 14, 2015 07:35 PM
dooner24
Apr 14, 2015 07:51 PM
Aznnp77
Dec 13, 2001 04:03 PM
