1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Speedometer and wiper issues
Old Jan 15, 2010
whateg01's Avatar
whateg01 is an unknown quantity at this point
I have a couple of questions that I can't seem to find answers to using the search, so...
'92 LX, AT
Since I bought this car, the wipers have always worked in lo/hi, but on intermittent they would go up about 5" and stop. Occasionally, they will work for awhile on int't, but usually they don't. Recently, they started coming on when I would start the car, regardless of the switch position. Sometimes, they would go one or two times before stopping. Other times, they just keep going. I have tried to change the switch position and they sometimes stop after that. But it is not repeatable enough for me to say that switching the switch position actually causes them to work right. Just this week, I replaced the switch assembly because the return function quit working and the switch would fall to the mist position. Didn't fix it, though.
About the same time, I think, as the wipers started coming on when I start the car, the speedometer stopped working. It first happened on my way home from work one day. I was driving along and suddenly it just went to 0. A couple miles later the CEL came on. I have noticed since then that the CEL comes on after about a few minutes of driving. All of my other instruments work. I also noted one day that slapping the shroud over the area behind the steering wheel caused the speedometer to work for a moment. Sometimes, it would jump up way to the right and then return to 0. I have all of the shrouds off right now for the wiper switch replacement and tried wiggling harnesses right under the steering column, but not clear back under the dash. Nothing seems to have an effect on the speedo. It's obviously a little difficult to do a lot of work up under the dash while driving down the road (the only time the speedometer is supposed to be somewhere other than 0).
Any ideas? From the description, do they sound related? I need to get to the library sometime and make a copy of the wiring diagram, but I'm not sure that the speedometer is an electrical issue. Is my speedometer mechanical or electrically operated? Does anybody have a wiring diagram that they can email me so I can troubleshoot the wiper issue?
edit: I have also confirmed that the battery and alt are ok by checking voltages running and off.
Dave
Old Jan 15, 2010
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Speedometer and wiper issues
an you locate a code reader to get the CEL code?
Old Jan 15, 2010
if new switch didnt fix it, you may need a new wiper motor and be sure the wiring is properly connected and plug terminals are cleaned and regreased with dielectric lube.
for the engine light, you need to get it checked. prolly gonna have to buy a scanner, since auto stores dont carry older than obdII (1995 and newer). may be a bad VSS (vehicle speed sensor) or something.
Old Jan 15, 2010
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
Domindart
Jun 4, 2015 09:20 PM
pratik05
May 15, 2015 01:54 PM
autowill
May 15, 2015 11:36 AM
shindrome
Exterior
May 5, 2015 02:50 PM
