02 civic lx 1.7 lit , man . trans knocking/rattling sound valve train
Old Dec 15, 2009
masangya's Avatar
masangya is an unknown quantity at this point
02 civic lx, 1.7 lit. non v-tec , man. trans. Trying to diagnose a baby knocking sound fr above # 1 cyl.. I adjusted the valves, didnt see anything obvious (i.e - rockers ,valves, springs,etc.). Comp. test is w/in specs.,eng. has almost 400 k miles,knocking sound around 2200 rpm.Mostly loud by intake w/ stethescope.Wondering if 1 of the rockers is out of tolerance, Any thoughts?
Old Dec 15, 2009
Boost Addicted's Avatar
Boost Addicted is an unknown quantity at this point
Re: 02 civic lx 1.7 lit , man . trans knocking/rattling sound valve train
Kinda confused as to whether or not you actually adjusted the valves?
Valve clearance is regular maintenance on this engine. Very simple to do.. I'm sure the guys here have a DIY. You need a 10(?)mm wrench, a flathead screwdriver, and some feeler gauges.
I had this same symptom and valve clearance adjustments solved the problem.
Old Dec 15, 2009
masangya's Avatar
Yes , i adjusted the valves n noise is still there.
mattdoc
Mar 14, 2017 12:10 PM
chrisod12
Apr 26, 2015 01:30 PM
vtechcivic
Apr 21, 2015 07:11 PM
bo_red
Apr 21, 2015 12:55 PM
showmedamoney
Nov 6, 2001 08:23 PM
