1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Fuel Pump Connections on 1980 Civic 1500 GL
Old Nov 9, 2009
packrat79's Avatar
packrat79 is an unknown quantity at this point
I probably should have drawn a diagram before taking apart the fuel
system, but in my haste to finish this project before winter, I guess I must
have forgotten. Anyway, the repairs have been made and it's time to hook up the fuel system components, but I'm afraid I'm going to need some help.
This tank has far more connections than the later Civics, and figuring out where they all go is going to be a problem. To help illustrate things, I've attached a crude drawing following this post, with numbers beside the various connectors. The two main filler hose connections are obvious (#1 to 14 and 2 to 13), but the rest are a mystery. The strangest thing is an odd series of pipes - one actually inside the other - that simply loops back to the tank instead of going anywhere, which was originally welded to the rest of the filler neck. Neither the Haynes or OEM manual gives even the vaguest illustration of these connections, so I'm pretty much at a dead end.
Any help would be appreciated.
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
