92 civic running rough
1992 civic dx sedan d15b7 new fuel pump plugs wires cap rotor fuel pressure regulator throttle body but still stumbles with a popping noise(detonation) in exhaust manifold and lacks power. if i pinch off the fuel return line at the regulator the car runs real strong and perfect. unclamped it wont accelerate much but seems to be ok in park and neutral. help please. update!!!!!new map sensor, no luck. car will run ok for a few seconds then like crap with a dtc 1. o2 tests okay fuel press. ok. can any one please help, im at the end of a short rope with this car!!
Re: 92 civic running rough
Did you check the ignition timing with a timing gun and the service connector jumped?
For code 1, have you checked the O2 sensor wires (voltage, shorts, continuity)?
dragonsblood
Apr 27, 2015 12:28 PM
civic_gt
Apr 19, 2015 08:15 AM
djdefcon
17
Apr 6, 2005 11:52 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
