1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
92 civic running rough
Old Aug 13, 2009
hilton0315's Avatar
hilton0315 is an unknown quantity at this point
1992 civic dx sedan d15b7 new fuel pump plugs wires cap rotor fuel pressure regulator throttle body but still stumbles with a popping noise(detonation) in exhaust manifold and lacks power. if i pinch off the fuel return line at the regulator the car runs real strong and perfect. unclamped it wont accelerate much but seems to be ok in park and neutral. help please. update!!!!!new map sensor, no luck. car will run ok for a few seconds then like crap with a dtc 1. o2 tests okay fuel press. ok. can any one please help, im at the end of a short rope with this car!!
Old Aug 16, 2009
RonJ's Avatar
RonJ will become famous soon enough
Re: 92 civic running rough
Measure the fuel pressure with and without the FPR vacuum hose connected and check the ignition timing with a timing gun.
Old Aug 17, 2009
hilton0315's Avatar
fuel pressure is constant throughout problem at 35 psi hose on 45 psi hose off. still dtc 1 new o2 sensor now still runs bad going to tackle ecm next i geuss
Old Aug 17, 2009
RonJ's Avatar
Did you check the ignition timing with a timing gun and the service connector jumped?
For code 1, have you checked the O2 sensor wires (voltage, shorts, continuity)?
Old Aug 17, 2009
hilton0315's Avatar
just checked timing--ok. replaced ecm--ok. distributor--ok. still runs like crap
compression check tomorrow
Old Aug 19, 2009
hilton0315's Avatar
its fixed, clogged fuel injector screens.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
dragonsblood
Apr 27, 2015 12:28 PM
civic_gt
Apr 19, 2015 08:15 AM
djdefcon
17
Apr 6, 2005 11:52 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
