VTEC Controller
Old Aug 4, 2009
01civictune's Avatar
01civictune is an unknown quantity at this point
VTEC Controller
I have a APEXI V-AFC II VTEC Contoller and Airflow Converter for an 01 Civic EX is it worth paying about $300 to have it installed and put on the dyno? also how would I keep the check engine and other lights from turning on doesn't this affect the ecu ?
Old Aug 4, 2009
greeen01civic4d's Avatar
Re: VTEC Controller
no effect on ecu, save money and get kpro, then dyno, way bigger diff
Old Aug 6, 2009
TRIZ's Avatar
Re: VTEC Controller
Yeah, for around 150 you could just buy the wireharness and make it plug and play so you dont have to change any wires up, cut or solder anything. Turning isnt really big on those things. Its more of a monitoring device.
Old Aug 6, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: VTEC Controller
300 for install and a tune is really cheap.. you can purchase plug and play harness for pretty cheap and install it yourself then pay for tuning separate.. but 300 for both is cheap, the tune alone should cost around 250-300. but honestly i doubt you will feel anything. maybe a minuscule 10 horsepower which is being very very generous. expect like 3-5. lol. unless your car is "highly modified"
Old Oct 10, 2009
JDM_Ricer's Avatar
JDM_Ricer is an unknown quantity at this point
Re: VTEC Controller
i would like to know how a vtec controller works.. ive searched up and down on yahoo... and ive got nothing... i just bought a buddy club vtec controller for 70 bucks
Old Oct 12, 2009
TRIZ's Avatar
Re: VTEC Controller
^ use google. It owns.
Vtec controllers just allow you to adjust Vtec kick in points. Thats it. Say you want it to kick in at 2,000 rpms... you can do that instead of having it kick in at the factory set point. Beware of your settings, setting it too low or two high can hurt the engine.
Old Oct 12, 2009
TRIZ's Avatar
Re: VTEC Controller
Old Oct 12, 2009
JDM_Ricer's Avatar
Re: VTEC Controller
Thats dumb lol. I already have it set at 4500 on my chrome chip... Anyone wanna buy a buddyclub vtec controller 70 bucks plus shipping lol
Old Oct 13, 2009
Re: VTEC Controller
triz is right, messing with the factory vtec setting is a very bad idea. the ecu uses a combination of four different variables before it will actually engage the solenoid. at least on newer 01+ civics, engine coolant needs to be at normal temp, oil pressure must be high enough, rpms above 4500, and throttle at 100%. if you program the vtec engagement yourself, even at 4500 rpms, you are bypassing ecu safety measures and can cause serious engine damage. imagine what would happen if vtec kicks in when your engine temp is cold, the rpm is too low, or you dont have enough oil pressure. goodbye motor.
Old Oct 13, 2009
GreenMachineDX's Avatar
GreenMachineDX is an unknown quantity at this point
Re: VTEC Controller
Good Explanation Gear.. All of us should know that tho..
Old Oct 15, 2009
TRIZ's Avatar
Re: VTEC Controller
Well, come to think of it- those that used a apexi vtec controler on their DX/LX with an EX headswap are in this situation. I havent heard of anyone blowing a motor over vtec engagement on a cold motor... but who knows, its probably happened- remember when everyone was blowing motors about a year and a half or two years ago? *shrug*
Old Oct 15, 2009
Re: VTEC Controller
then there is also the problem of the ecu adjusting to the tuning.
Old Oct 15, 2009
TRIZ's Avatar
Re: VTEC Controller
Yup, so whatever you set in the vafc2, the ecu will eventually override.. Any tuning is a waste.
Kevinsisco
Aug 31, 2015 12:04 AM
Mike_47
Transmission
Jul 8, 2015 02:42 PM
