Wobbly stick shift
Wobbly stick shift
I have a 98 Civic with a 5 speed. The shifter is very wobbly and bounces all around. I've heard that there is a bushing of some kind under the shift mechanism that can be replaced. Does anyone know of this and how hard it is to remove/replace?
Thanks
Thanks
Re: Wobbly stick shift
Check majestic honda for a parts blowup of the shift lever. It should be easy to replace.
Pull the center console and unbolt the shifter- there are 4 bushings sitting underneath it. Replace them with aluminum ones if you want a better feeling in the shifter. Also, there are bushings, rubber, where the shift cables connect to the tranny, looks like part 14 in that diagram posted above. They get torn and deteriorate over time. Raplace them with aluminum ones as well if made for your car. (check password JDM or strutking or some other aftermarket parts places).
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
