Wobbly stick shift
Old Jul 24, 2009
1923flyer's Avatar
1923flyer is an unknown quantity at this point
Wobbly stick shift
I have a 98 Civic with a 5 speed. The shifter is very wobbly and bounces all around. I've heard that there is a bushing of some kind under the shift mechanism that can be replaced. Does anyone know of this and how hard it is to remove/replace?
Thanks
Old Jul 24, 2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Re: Wobbly stick shift
Thanks
I've never removed it but... maybe your engine/trany is moving excessively? The shifter rod attaches to the back of the trany. How steady is your idle?
Check majestic honda for a parts blowup of the shift lever. It should be easy to replace.
Old Jul 24, 2009
1923flyer's Avatar
Idle is steady and car runs well. Nothing seems to be loose.
Old Jul 24, 2009
http://www.hondaautomotiveparts.com/...y5=SHIFT+LEVER
Old Jul 24, 2009
TRIZ's Avatar
Pull the center console and unbolt the shifter- there are 4 bushings sitting underneath it. Replace them with aluminum ones if you want a better feeling in the shifter. Also, there are bushings, rubber, where the shift cables connect to the tranny, looks like part 14 in that diagram posted above. They get torn and deteriorate over time. Raplace them with aluminum ones as well if made for your car. (check password JDM or strutking or some other aftermarket parts places).
Old Aug 5, 2009
bluetwo's Avatar
bluetwo is an unknown quantity at this point
Bushings.... if you still care.
You can probably find bushings that will work at most parts stores, of course, aluminum bushings would give you the tightest feel.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
ThatGuy913
Sep 28, 2015 05:35 PM
