Rear arm pivot nut came loose - suggestions to take it out
Old Jun 14, 2009
Nut weld came loose and can't get the bolt out...
There's no space for vise because of the strange metal around it (why is it there anyway?)
Was thinking on welding it back using a spot weld. Can't even cut it out because of a (Eibach?) brace does not give clearance for a saw and heating the nut did not help much...
Love Honda engineers, but sometimes I feel like killing some of them...
Old Jun 14, 2009
silver25civic's Avatar
silver25civic is an unknown quantity at this point
Re: Rear arm pivot nut came loose - suggestions to take it out
did you post some pics of it? if so they didnt show up.
Old Jun 14, 2009
did you strip the nut trying to take it off?
Old Jun 14, 2009
edited just now. see the vise grip marks in the nut (they should have used a Hex nut welded there... hate them right now.
Old Jun 14, 2009
try using some needle nose vise grips they are alot thinner than regular vice grips.
Old Jun 14, 2009
No, the nut is supposed to be welded in there, circled by these strange stuff. It does not have a HEX, it's simply a smooth round nut with threads... Hate, hate, hate honda engineers!
I was supposed to be on the AutoX today...
Old Jun 14, 2009
Yeah, they were the ones that left the marks. sniff.
I might ask my friend to lend his pitbull, but i don't think the head will fit in this tight space...
Old Jun 14, 2009
the top ones or bottom ones?the top are regular vise grips and bottoms are needle nose vise grips.
ID:	76698   Click image for larger version
Old Jun 14, 2009
Oh, well, will try to fight some more and come back later to give results or else for more options... At least for now, I could force the bolt back to tighten, so it can run for now.
Old Jun 14, 2009
Tried both, actually. both will be straight in the direction of the bolt, so can't get torque enough to take the bolt off (last portion might be stripped...)
Ah, tried using an electrical impact wrench (which helped me tighten back the suspension wile I think what to do), but could not take it out becuase vise will come loose.
Old Jun 14, 2009
BTW, silver25civic, if you are a Honda suspension engineer, don't mind what i said! But if you really are, please use a hex nut welded there!
That way, even if it came loose, I can still use a normal wrench!
Old Jun 14, 2009
nothing like a bigger vise - found a bigger neddle type and was able to take it out. Nut have 3 protruded parts under the nut which fits on similar slots in the suspension (welds?). Anyway, time for a spin and count the number of bolts that will fall in the way.
Thanks for the help silver25civic
Old Jun 15, 2009
See the lovely fella here
But now all is well, after the new vise grip
Car drives well beyond the limits before, way less understeer. Need to recalibrate rear and front shocks now.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
bryden13
May 18, 2015 12:22 PM
Pudnite
May 9, 2015 07:51 PM
shindrome
Exterior
May 5, 2015 02:50 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
