Not a covered swap question
Old Jun 7, 2009
sleekcivic2004's Avatar
sleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nice
Question Not a covered swap question
Alright guys i have a '90 hatch with no motor gathering dust and 2 complete d17a2 motors, ecus, and trannys. Anyone have knowledge of this being done? I thought I would try to get some info from here first. I'm sure i'll just end up having to get the cherry picker and lower it down in there and go from there. If memory serves me I think I remember the d15 tranny mounting to the d17. I have a good d15 tranny if that would make fitment and axles easier.
thanks
Old Jun 7, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: Not a covered swap question
I don't believe any older d-series trannies will mate up to a d17 block. I vote go for it. You may run into some problems with the electronics and harnesses and stuff of that sort, you will probably need an engine and dash harness from the d17, but it should be possible. You will have to make custom mounts too, but it shouldn't be that bad.
Old Jun 7, 2009
thats what i figured on the mounts and I have a complete harness from the EX that the engine, tranny, and ecu came from so that should eliminate that issue.
Old Jun 7, 2009
CanadianCivic02's Avatar
CanadianCivic02 is an unknown quantity at this point
dont think it would work, the d17s have alot more sensors and those sensors = pain in the ***
it would just be better to get an older d15 and swaping it in
Old Jun 7, 2009
baron340's Avatar
Granted the older motor would be much easier, the if you have the whole harness, ecu and engine, the sensors shouldn't really be an issue. The only situation where this swap is practical on any sort of level is if you have an older motor-less car sitting around along with the engine and stuff. This seems to be your situation so I say go for it.
Old Jun 7, 2009
what does that have to do with anything when i am using the entire a2 engine, transmission, ecu, and harness. the only things are i wont hook up abs, srs, things of that sort. i would be using all the engine sensor because i would be using the ecu for it. i know as far as connecting the clutch linkage that will be custom. also get the speedo and guages to read might be another issue. if so i'll just do a custom instrument cluster.
Old Jun 7, 2009
that what i was thinking
Old Jun 7, 2009
BlueEM2's Avatar
Whachya lookin at?
Do it up! Take pictures and post em!
Old Jun 7, 2009
i plan on getting to it as soon as possible. i'm wanting see if there is anything that i hadn't thought of on my own first though......i own my own business and it ties up a lot of my time. i will post my progress though.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
nontypical
May 4, 2015 04:10 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
viper775
Dec 9, 2001 10:52 PM
WhosYoDadday85
Nov 13, 2001 09:38 PM
