cruise control problem
Old Apr 22, 2009
servicetech77's Avatar
servicetech77 is an unknown quantity at this point
I have a 2001 Civic EX w/ manual tran. and 160k miles. Recently, I have noticed that while in fifth gear and cruise on, if I go 65 mph or more it will pop me out of gear into netural. It does not do this if cruise is off, I can go whatever speed and it's fine. Has anyone heard of this happening? Thank you.
Old Apr 22, 2009
Re: cruise control problem
could be a loose cruise control cable. see if there is alot of slack in the cable and tighten it up.
Old May 21, 2009
Symon's Avatar
Symon is an unknown quantity at this point
well, I'm new, this being my first post, so I'm not sure if this is a bump or not but I have the same car just a bit more mileage. The cruise control doesn't work at all and the horn on the steering wheel doesn't work but it will honk with the keyless entry. Any help would be great.
Old May 21, 2009
could be a blown fuse or fuses.
Old May 21, 2009
Symon's Avatar
yah I checked the fuses, tried the relay on the lights to see if the relay was good or not and the lights still worked with that relay. . .
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 27, 2015 12:04 PM
cukaracha
May 16, 2015 02:11 PM
Civic316
Electronics
Dec 10, 2001 12:03 PM
