Turn on ac at idle speed, engine shuts off
Old Apr 22, 2009
ABMonroe's Avatar
ABMonroe is an unknown quantity at this point
I recently has some routine maintenance done to my 99 honda civic lx. now, whenever my a/c is on and my engine is at idle speed, my car shuts off. i turn off a/c and my car idles fine. a friend said it has to do with battery power being disrupted at time of maintenance...that a sensor went to default settings and it needs to be reset. sound familiar? if so, what sensor?
Old Apr 22, 2009
Re: Turn on ac at idle speed, engine shuts off
yeah the ac will lower the idle speed, sometimes enough to make the engine die. but your iac valve should adjust and let in more air to raise the idle. i would clean out all the intake parts like throttle body and any valves around it. then put it all together and reset the ecu. drive the car til its warmed up, then turn off and disconnect the battery. reconnect, start car, and let it idle for 10 mins without pressing gas or using accessories. turn car off. idle speed should be set.
Old Apr 29, 2009
ABMonroe's Avatar
awesome - thanks for the info!
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
jakeconnor
May 5, 2015 07:30 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
redej2
Apr 29, 2015 01:47 PM
