Turn on ac at idle speed, engine shuts off
Old 04-22-2009
ABMonroe's Avatar
ABMonroe is an unknown quantity at this point
I recently has some routine maintenance done to my 99 honda civic lx. now, whenever my a/c is on and my engine is at idle speed, my car shuts off. i turn off a/c and my car idles fine. a friend said it has to do with battery power being disrupted at time of maintenance...that a sensor went to default settings and it needs to be reset. sound familiar? if so, what sensor?
ABMonroe is offline
Old 04-22-2009
Re: Turn on ac at idle speed, engine shuts off
yeah the ac will lower the idle speed, sometimes enough to make the engine die. but your iac valve should adjust and let in more air to raise the idle. i would clean out all the intake parts like throttle body and any valves around it. then put it all together and reset the ecu. drive the car til its warmed up, then turn off and disconnect the battery. reconnect, start car, and let it idle for 10 mins without pressing gas or using accessories. turn car off. idle speed should be set.
gearbox is offline
Old 04-29-2009
ABMonroe's Avatar
awesome - thanks for the info!
ABMonroe is offline
CarStuff
12-06-2020 12:52 PM
ImmortalEX
Detailing
78
09-04-2015 05:35 PM
jakeconnor
05-05-2015 07:30 AM
Geoff_Geoff
16
04-30-2015 12:17 AM
redej2
04-29-2015 01:47 PM
Quick Reply: Turn on ac at idle speed, engine shuts off
