2003 civic side mirror replace diy?
Re: 2003 civic side mirror replace diy?
Pry the triangle off, just a flat tip screw driver it pops right off. Inside is 3 8mm nuts, undo those, unplug the harness and it will come off. I had to kinda of jiggle the connector for the harness free on mine. Hope this helps.
BUN
BUN
got it! haha looks great someone kicked my old mirror off but the plastic was still ther, i got a new off ebay poped the miiror off was held on w/ glue on the oem, unscrewed broken internals and replaced with new mirror internals voila! oem/new mirror!
Back before I knew better, I actually went to the stealership for a replacement side mirror. Ran me about 85 bucks....
But I guess the thing that scares some people off from doing this is that they might crack something while taking the triangle off. Guess it's just practice.
Does this work on 2001 model? I need to replace the passenger side mirror - do I need to take off the whole panel or only the triangle inside? Anyone has pics of how to take off the panel, in case I need to do it? Thanks.
Pop the triangle off, aka the sail panel, 3 bolts and a small connector you need to pull apart, mirror falls off. EASY. Same on all 7th gens, and prob other gens as well
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
thesushiboy
Apr 12, 2015 02:54 AM
