2003 civic side mirror replace diy?
Old Apr 19, 2009
ross3093's Avatar
ross3093 is an unknown quantity at this point
how do i replace a side mirror on driver side 03 civic ex do i need to remove the door panel? i cant get the little piece of triangle plastic off........
Old Apr 19, 2009
chinaman516's Avatar
chinaman516 will become famous soon enough
Re: 2003 civic side mirror replace diy?
Pry the triangle off, just a flat tip screw driver it pops right off. Inside is 3 8mm nuts, undo those, unplug the harness and it will come off. I had to kinda of jiggle the connector for the harness free on mine. Hope this helps.
BUN
Old Apr 19, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
When you put it back on, don't over tighten the three bolts!
Old Apr 19, 2009
manahoonie's Avatar
/\/\ a good hand-tight is enough.. they're just holding a mirror on. if they start to get loose, you'll notice in plenty of time :P
Old Apr 19, 2009
ross3093's Avatar
got it! haha looks great someone kicked my old mirror off but the plastic was still ther, i got a new off ebay poped the miiror off was held on w/ glue on the oem, unscrewed broken internals and replaced with new mirror internals voila! oem/new mirror!
Old Apr 20, 2009
manahoonie's Avatar
lol. good job, i guess :P (just haven't seen pics of it lol)
Old May 9, 2009
Matt300's Avatar
Matt300 is an unknown quantity at this point
Back before I knew better, I actually went to the stealership for a replacement side mirror. Ran me about 85 bucks....
But I guess the thing that scares some people off from doing this is that they might crack something while taking the triangle off. Guess it's just practice.
Old Feb 11, 2010
Civicized's Avatar
Civicized is an unknown quantity at this point
Does this work on 2001 model? I need to replace the passenger side mirror - do I need to take off the whole panel or only the triangle inside? Anyone has pics of how to take off the panel, in case I need to do it? Thanks.
Old Feb 11, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Yes, it should be exactly the same procedure.
Old Feb 11, 2010
TRIZ's Avatar
Pop the triangle off, aka the sail panel, 3 bolts and a small connector you need to pull apart, mirror falls off. EASY. Same on all 7th gens, and prob other gens as well
usajags84
May 10, 2015 08:11 AM
Fastfebur
Apr 22, 2015 01:37 PM
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
thesushiboy
Apr 12, 2015 02:54 AM
