Trunk Release Handle Stuck In Locked Position
Help!
I have a 2005 Honda Civic LX Special Edition. My trunk release handle has a lock on it, so you can use the master key to lock the trunk release handle, preventing the trunk from being opened from inside the car. Last week I locked the trunk handle, but have been unable to unlock it. I insert the master key and turn it from the locked to the unlocked position, but the handle is still locked somehow. When I turn the key, I don't seem to feel any resistance from inside the locking mechanism, so I have a feeling something's come undone in there.
I'd like to fix this myself if it's something simple. Anybody know how I can go about opening the sucker up to see what's going on and/or how to fix it?
Re: Trunk Release Handle Stuck In Locked Position
ignore everything i say.
you could probably just pry the plastic cover off, and move the lock manually :P
but then if u crack it (and u will) ud have to buy a new cover, but i doubt they could be too expensive :P
that lock is a joke lol. yeah just try to pry out the top plastic piece and play with it. spray some lube in the hole too maybe its jammed. i dont even use it cause if you forget its locked and yank the handle, it will prolly snap off.
I also have the same problem! Did anyone find a solution?
Trunk release will not work. The key will turn the lock but the handle never becomes operational...
Are there any good sites for the TSB?
I had the same thing recently, I used a multi-folded sheet of paper wedged between the lock cylinder and the metal bracket on the rear side. It moved the bottom of the cylinder forward and allowed the 2 mechanism to start meshing again and it has worked fine since.
Once the covers are removed the lock cylinder can be pryed straight up for removal.
DerbyDad03
Exterior
May 16, 2021 10:07 AM
Adam925
Nov 19, 2019 10:56 AM
geoffm1234
Exterior DIY
Jun 3, 2015 08:18 PM
carhag2000
Apr 25, 2015 01:33 PM
