Fog Lights Not Working!
Old Mar 27, 2009
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
Question Fog Lights Not Working!
I've had my foglights (ebay oem style) on my car for the longest time, with the 04 Civic Fog Light Wire Harness and Honda Pilot Fog Light Button...all have been working for around 3 years...I went to install my yellow h11 bulbs last night at work...I turned on the car, turn on my headlights (HID), then hit the fog light button...the fog lights turned on for a second then went off...now they won't come back on.
I've taken the bumper off to get a good look at all my wires and connections and double checked the ground, but I don't think the problem is in front of the car, I think its behind the dash panel...I double checked the relay (Honda OEM relay), and that was fine. I press the fog light button in and the green light illuminates.
I checked all possible fuses (the only one I can think of is FUSE #18 under the steering wheel), and it wasn't burnt out. I'm clueless as to what it might be....I already swapped out the yellow bulbs with the stock bulbs and they don't work either. I need some opinions and help on what it might be. Thanks guys!
Old Mar 27, 2009
sl33pyriceboi's Avatar
Re: Fog Lights Not Working!
if you bought it from ebay, you have a seperate fog fuse. trace the wires and find that fuse.
btw, who installed it, you or someone else?
Old Mar 28, 2009
I bought the fog lights on ebay, but i didn't use the wire harness(that goes in the dash)...only the harness for the lights itself (2 grounds, 2 plugs for fog lights, and brown connector that connects to stock brown connector on the car). There is no fuse that I have seen on both harnesses...
I installed it...and I followed the Honda Diagram for the 04' Civic which breaks it down step by step.
I took the fog light harness off the car tonight and examined it...it looked totally fine...i split the loom and checked the wires...they were still intact and not burned or anything. I'm guessing its a fuse somewhere. I will check autozone.com and see if I can find it. Thanks for the reply...any help is welcome.
Old Mar 28, 2009
Well slap me sideways...i just found what may end up being my ****in' fuse....i totally forgot all about it...there is a 20A fuse on the back of the fuse box connected to the switch harness...i gotta check it out when i wake up...i ****in' hope thats it.
Old Mar 28, 2009
EM2_01's Avatar
EM2_01 will become famous soon enough
Smile Re: Fog Lights Not Working!
well if ya need help i can show you how i did mine with a ebay fog light kit... also i used a 30 amp fuse seperate from the car one just for the fog lights... i only used the one harness that came with it that plug up to the fog lights then at the end of that harnes i made my own wiring with a different toggly swith from radio shach.. cost bout only 4.00, then mad a negative wire to ground and ran a power wire with inline fuse holder ( 30am fuse) from positive sid eof battery then to the power of the toggle swith... and yaaa... all set.... well if ya need help just instant mssg me on aol and i can come through since yer in sac... aol: EM2Civic01
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
