Help on proper tire pressure for 245/45ZR/17
Old Mar 26, 2009
02_civiclx's Avatar
02_civiclx is an unknown quantity at this point
Called America's Tire Co. and guy said should be 35 Psi. Does anyone know what the proper tire pressure is for Raptor Riken 245x45x17?
Thanks!
Old Mar 30, 2009
Zzyzx's Avatar
Autocross Junky
Re: Help on proper tire pressure for 245/45ZR/17
Tire pressure is mainly based on weight. And it is clearly marked in side the drivers door sill. you may as an option increase that designated psi by 1 or 2 lbs if you like.
Old Mar 30, 2009
04 Honda Civic's Avatar
Its on the sidewall on all tires isnt it?
Old Mar 30, 2009
sl33pyriceboi's Avatar
^no. the sidewalls tell you the MAXIMUM pressure allowed to safely operate the tire.
our pressure is somewhere along the lines of 30-32psi
Old Mar 30, 2009
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
^^^^^^^ that is correct... just run 33 or 34 with a tire like that running 32 might be a little to soft and then you run the risk of a nice blowout off a pot-hole well actually reguardless a tire like that will suffer from anything but smooth *** roads. good luck
Old Mar 30, 2009
ah good to know, never knew that
Old Mar 30, 2009
i run 31ish psi during the summer time and about 32psi during the winter...
but here in cali, the temp doesnt really ever change.... 75degrees of sunny blue skies year round
Old Mar 30, 2009
i like 35 psi in the summer its not too harsh. in winter tho everything is very stiff.
Old Mar 31, 2009
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
running 34lbs up front and 40 in the rears in my hankook rs-2's. use to run 32/36.
Causemo
Jul 4, 2015 07:11 AM
bo_red
Apr 23, 2015 10:09 PM
2k1USMCivic
Jan 1, 2002 01:24 PM
artychris
Oct 24, 2001 10:14 AM
