Timing Belt change- is it due?
Old Mar 26, 2009
Civic Novice's Avatar
Civic Novice is an unknown quantity at this point
I have just brought a Civic 1.6 VTEC Sport (03) and it has done 39,000 miles. I am not sure when the timing belt and other associated parts mentioned in some threads will need to be replaced. The manual talks about 5 yrs or 50,000, which ever comes first. As this seems to be a very costly job, I fear that I may have a lot of unexpected costs coming my way. Any advice would be good.
Old Mar 26, 2009
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Re: Timing Belt change- is it due?
Just inspect it. If you spider cracks or if you touch it and it feels dry/brittle replace it. I have 77,000 miles on my 01 and its still fine. I even spent some summers is the AZ desert.
Old Mar 26, 2009
colourwolf's Avatar
colourwolf will become famous soon enough
You need to take alot of things off in order to check the timming belt.Unless you are doing it yourself, otherwise it doesnt worth to find a mechanic to inspect it. Just change it, it is more cost effective.
Old Mar 26, 2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
I would change it before it passes 6 years I have had one go that only had 50,000 miles on cause it had been on the car over 6 years
Old Mar 27, 2009
rutscivic's Avatar
rutscivic is an unknown quantity at this point
A timing belt, water pump, accessory belts, and coolant is replaced every 8 years or 105,000 miles ...AT least that's when our dealership recommends them.
mattdoc
Mar 14, 2017 12:10 PM
S.Klinck
Jun 11, 2015 10:27 PM
mrohitredd
18
May 14, 2015 07:35 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
