need some ideas
Old Nov 23, 2008
daipergravvy's Avatar
daipergravvy is an unknown quantity at this point
need some ideas
so im about to come into some money and looking for a good way to spend it on my 01 civic...i really want to boost it, but need some input on the stuff that i will need to prepare for it...i plan to boost on stock internals for the time being, but id like to know some other mods that will coincide with a turbo...
Old Nov 23, 2008
TRIZ's Avatar
Re: need some ideas
Anything. ...be more specific.
Old Nov 23, 2008
Re: need some ideas
well...the obvious things i will need is ecu and exhaust manifold, but should i also look toward pulleys too and maybe a clutch?
Old Nov 23, 2008
TRIZ's Avatar
Re: need some ideas
Did you search? Info is out there.
You can pick up a cat back. Pulleys are a bad idea except for the power steering pulley, the others will underdrive your alternator and screw up your block/crank. Clutch doesnt need to be done for turbo- stock will hold if your still boosting on stock internals. Intake manifold will be fine as well- you wont crack it.
You really should focus on getting your turbo parts first, and doing the swap, before you go looking for other frilly parts to waste money on.
Old Nov 23, 2008
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: need some ideas
just get the dezod kit from www.dezod.com
I think it includes just about everything you need.
Old Nov 24, 2008
TRIZ's Avatar
Re: need some ideas
I think you still need a management system, but yeah it has all the parts needed.
Old Nov 24, 2008
Re: need some ideas
any suggestions for an ecu?
Old Nov 24, 2008
speedfoos's Avatar
Re: need some ideas
Jiminy Christmas.....
I'm gonna say no, he did not.
Stock clutch will start to slip above 160whp.
For an "ECU" you either need to run kpro or a piggyback EMS.
Take some time, look around the site, educate yourself a little on what goes into a turbo build (and why), and then come back with a build thread that lays out your plans and put your more specific questions in there.
aultman1990
Jul 9, 2015 08:27 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
Mike_47
Transmission
Jul 8, 2015 02:42 PM
SpecialRequest
Jul 7, 2015 07:52 PM
robbie374
Jul 7, 2015 02:56 AM
