Rust on bolts on exhaust manifold cover
Old Nov 15, 2008
diamente's Avatar
diamente is an unknown quantity at this point
What should I do with it? I am afraid if I spray WD 40 or other grease, it would catches fire because WD 40 and other grease are flammable.
Old Nov 16, 2008
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Re: Rust on bolts on exhaust manifold cover
Man if you're worried about rust on bolts then I hate to break it to you but you've got a whole can of worms to deal with. And what's going to light the wd-40 on fire? There's no way I can thnk of. And the kerosene in it evaporates within the hour or so.
Old Nov 27, 2008
97EXSweetSusie's Avatar
97EXSweetSusie is an unknown quantity at this point
Take some PB blaster to it and an air gun if u really need to or a breaker bar whatever u have a get those things off as long as u arent using a open flame to see under your car u are fine it will evaporate in a few mins and u will have no problems
Old Nov 28, 2008
Guso's Avatar
Guso is an unknown quantity at this point
the best thing to do is get a tourch and heat it up. its the only way u can do it!
Old Dec 23, 2008
guachi's Avatar
guachi is an unknown quantity at this point
I sprayed bunches of WD 40 on mine and it never cached on fire, as the other member said it evaporates within a few minutes... should not worry about it...
Old Dec 23, 2008
JoshD's Avatar
JoshD will become famous soon enoughJoshD will become famous soon enough
Pour Hydrochloric Acid all over it
Old Dec 28, 2008
sql_civic's Avatar
Just spray it when it's cold.
Old Dec 28, 2008
04 Honda Civic's Avatar
rofl, rags should be a shop tool for everyone
D17A7
Jul 6, 2015 06:04 AM
Reverb2005
Jun 26, 2015 06:22 PM
Supramk3
May 11, 2015 07:55 PM
Civic4ever1996
Apr 16, 2015 08:30 PM
AEMcivic
Dec 5, 2001 04:02 PM
