1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
slid into a kerb yo, while doin mad tyte tokyo dorifto
Old Oct 11, 2008
gnesis's Avatar
gnesis is an unknown quantity at this point
Okay so i need some help here, two days ago was first snow/first ice on the roads. I hit some black ice and curbed my left rear wheel. I'm driving a 94' civic ex w/ abs. I dented my steel wheel but i got that fixed. Now my problem is that i have slight positive camber on my wheel. It's very slight and i haven't noticed a difference in driving, but then again i just put on studded tires after the accident. What do you think I screwed up? The camber issue is very very minor, and you wouldn't notice unless you looked hard, but I'm sure that it would definitely wear down my tire over time. So what do you guys think? I'll try to get some pics if i can borrow my brothers camera.
Thanks
okay i got some pictures to show ya'll
[img=http://img399.imageshack.us/img399/9023/104df4.th.jpg][img=http://img399.imageshack.us/images/thpix.gif]
Old Oct 11, 2008
Re: slid into a kerb yo, while doin mad tyte tokyo dorifto
need to get an alignment, any time you crash the car lol
Old Oct 11, 2008
gnesis's Avatar
yeah, but i'm worried that i might of hurt something else, i'm a noob... but these cars stock don't have the ability to modify the camber does it?
Old Oct 11, 2008
no but you need to take it in and tell em what happened. they will inspect other suspension components to make sure nothings loose. and can prolly align it again to stock specs.
Old Oct 12, 2008
TRIZ's Avatar
You can make slight +/- camber adjustments with the stock arms, but its next to nothing. If you can visually see it then you probably messed something up, or if you didnt, you just shifted the camber arm within the mounting holes and its all good. Take it to an alignment shop.
Old Oct 28, 2008
huntinghonda27's Avatar
huntinghonda27 is an unknown quantity at this point
These cars are a little sturdier than you might think. Just go to a shop tou trust to get it aligned and you should be fine. Even if you do need to replace something you can probably find it at a junkyard. Even with studded tires you should still be able to tell if something is seiously out of whack after a few weeks, as it will get worse.
MichaelLW
Sep 14, 2015 07:15 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
Brad Andrew
Sep 8, 2015 08:25 PM
2005seTO
Aug 18, 2015 12:45 PM
