1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
just bought an 87 DX HB - any ideas?
Old Sep 28, 2008
1987DX2D's Avatar
1987DX2D is an unknown quantity at this point
I'm broke as hell, and enjoy getting good fuel economy, so I just picked up "Rita" to replace my 93 Isuzu Rodeo gas guzzling *****.
Rita's an 87 DX HB. Anything I should watch out for on this particular model mechanically? She seems to run great so far and I checked her out pretty good prior to the purchase. Only 119k miles.
Only thing I've noticed is the clutch slipped a lot when I started from a stop in 2nd once. But no problems as long as I start in 1st. I'll check the clutch adjustment within the next couple of days.
Also the AC doesn't work (compresser sounds good though) and I'm SURE an 87 ran R12, so I'll be looking for a 134 kit come summertime..
Any hints/advice/etc is welcome.
Old Oct 28, 2008
huntinghonda27's Avatar
huntinghonda27 is an unknown quantity at this point
Re: just bought an 87 DX HB - any ideas?
You need to do a good tune up. Check your compression, replace all underhood ground wires. DO NOT run your ac again with no refrigerant in it (if that is what the problem is) since you would possibly be pulling in moist air through a leak. It is only a possibility, not certain but since vehicle ac compressors are usually rotary compressors it is not a good idea to maybe pull non compressable moisture into it. Make sure your carb is clean and check all of your vaccum lines and emissions equipment for optimum mileage. To increase mileage you can use grill blocks but you need to have some way to open them for radiator airflow in the summer and keep an eye on your temp gauge. You can also fab up a new undertray panel in the front for better airflow. In a car this old there are a lot of possibilities for increasing FE.
mistermenphis22
Apr 3, 2016 08:06 AM
beneditti
Jan 15, 2016 12:31 PM
Supramk3
May 11, 2015 07:55 PM
Marcus2thextrem
May 10, 2015 03:08 PM
pheaton
May 4, 2015 08:26 PM
