g35 retrofit
g35 retrofit
Did a retrofit in my 2002 civic and need help with high beam wiring currently i have only low beam working. I have the g35 bi-xenon projectors. Im thinking this wiring will work if anyone knows let me know.. Here are some pics..
Then i was bored and did a front end converstion..
and this is the wiring my car is ground switched..
Re: g35 retrofit
Re: g35 retrofit
Re: g35 retrofit
I have fx projectors that look very similar. Just hooked them up to bixenon harness i bought and it was good. I dont think the polarity matters for the solenoid i remember testing it with a 9v battery and it was enough to trigger it, all they need is the power source and they should work
Re: g35 retrofit
yeah thats what i figured, given the superior output of the tl's. Then again any hid projector will be a huge improvement over stock...shroud it up and you got a winner.
Post some wall shots too, so we can see the cut offs.
Re: g35 retrofit
Oh a huge improvement over stock, this is my first retro just wanted to try it and love the result. It not the same as slaping some hids in like everyone does. These have a nice cut off line that dont interfere with other drivers, will have more pics soon. And when you say a shroud that is a cover covering the back part and only showing the projector? What is the whole purpose of it i know during day if i have the lights on i could see a bit of light showing on back part of headlight.
Re: g35 retrofit
This is a pic from my e46 retro on my old civic.
Re: g35 retrofit
what did you use to create the shroud? I seen people use old shirt and (something weld cant think of a word)
Re: g35 retrofit
i bought some e46 shrouds then cut it and enlongated it with fiberclass to cover it up to prevent any light leakage.
You can probably just use the shroud stock since the spacing in the 01-03 head lights are a lot larger then the 04-05
http://cgi.ebay.com/ebaymotors/BMW-E...spagenameZWDVW
you might want to double check the diameters though, i forgot if g35 projectors are 2.5'' or 3''
blackcivic28
Jan 30, 2004 12:04 AM
HondaGuru
22
Apr 26, 2003 02:21 PM
