g35 retrofit
Old Sep 3, 2008
DirtyCivic's Avatar
DirtyCivic will become famous soon enough
g35 retrofit
Did a retrofit in my 2002 civic and need help with high beam wiring currently i have only low beam working. I have the g35 bi-xenon projectors. Im thinking this wiring will work if anyone knows let me know.. Here are some pics..
Then i was bored and did a front end converstion..
and this is the wiring my car is ground switched..
Old Sep 3, 2008
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Re: g35 retrofit
https://www.civicforums.com/forums/a...2&d=1156304629
Old Sep 3, 2008
DirtyCivic's Avatar
Re: g35 retrofit
the g35 projectors come with a motor that moves so you get hight beams.
Old Sep 3, 2008
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
Re: g35 retrofit
nice retro, looks good!
Old Sep 4, 2008
electric130's Avatar
Re: g35 retrofit
wiring diagram looks like it should work. is it not working?
Old Sep 4, 2008
sl33pyriceboi's Avatar
Re: g35 retrofit
if u place ur diode in a negitive current, put it backwards for a forward flow. thats wt i found out when i did mine. mine works.
Old Sep 4, 2008
Re: g35 retrofit
he's not using a diode in that diagram. doesn't need one either.
Old Sep 5, 2008
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
Re: g35 retrofit
I have fx projectors that look very similar. Just hooked them up to bixenon harness i bought and it was good. I dont think the polarity matters for the solenoid i remember testing it with a 9v battery and it was enough to trigger it, all they need is the power source and they should work
Old Sep 5, 2008
TemjinX2's Avatar
Re: g35 retrofit
nice, you just needs some shrouds. why g35 bixenons instead of TL's? cost?
Old Sep 5, 2008
DirtyCivic's Avatar
Re: g35 retrofit
I havent built the wiring harness yet. .Just wanted to see if this one would work.
Old Sep 5, 2008
DirtyCivic's Avatar
Re: g35 retrofit
I didnt go with the TL's because i got these for almost nothing.
Old Sep 5, 2008
TemjinX2's Avatar
Re: g35 retrofit
yeah thats what i figured, given the superior output of the tl's. Then again any hid projector will be a huge improvement over stock...shroud it up and you got a winner.
Post some wall shots too, so we can see the cut offs.
Old Sep 6, 2008
DirtyCivic's Avatar
Re: g35 retrofit
Oh a huge improvement over stock, this is my first retro just wanted to try it and love the result. It not the same as slaping some hids in like everyone does. These have a nice cut off line that dont interfere with other drivers, will have more pics soon. And when you say a shroud that is a cover covering the back part and only showing the projector? What is the whole purpose of it i know during day if i have the lights on i could see a bit of light showing on back part of headlight.
Old Sep 6, 2008
TemjinX2's Avatar
Re: g35 retrofit
no real purpose other then making the car look like it came like that from the factory. It'll just make your retro seem more complete.
This is a pic from my e46 retro on my old civic.
Old Sep 6, 2008
DirtyCivic's Avatar
Re: g35 retrofit
what did you use to create the shroud? I seen people use old shirt and (something weld cant think of a word)
Old Sep 6, 2008
TemjinX2's Avatar
Re: g35 retrofit
i bought some e46 shrouds then cut it and enlongated it with fiberclass to cover it up to prevent any light leakage.
You can probably just use the shroud stock since the spacing in the 01-03 head lights are a lot larger then the 04-05
http://cgi.ebay.com/ebaymotors/BMW-E...spagenameZWDVW
you might want to double check the diameters though, i forgot if g35 projectors are 2.5'' or 3''
WannaBFast
Sep 1, 2004 12:41 AM
blackcivic28
Jan 30, 2004 12:04 AM
Boosted2k2
North East
21
Aug 27, 2003 06:24 PM
HondaGuru
22
Apr 26, 2003 02:21 PM
IonRays
Apr 11, 2002 11:33 PM
